Электротранспорт
Расширенный поиск
Новости:
Страницы: 1Вниз
Автор Тема: 1)Повышающий модуль 600W DC-DC, 2) ручка "газа", Санкт-Петербург самовывоз  (Прочитано 321 раз)
caprid
  • Начинающий
    +0/-0
    13
    2
  • Санкт-Петербург
  • Ездю на батарейках!
  • Оффлайн Оффлайн
    • Награды
1)
Brand   N/A
Model   N/A
Quantity   1
Color   Blue
Material   Glass fiber + electronics components
Specification   Working temperature: -40'C~+85'C; Working frequency: 150KHz
Features   Mobile, car charger, laptop power supply
Application   600W DC-DC boost module, mobile, car charger, laptop power supply
English Manual/Spec   Yes
Other   Module Parameters: 600W booster module with constant current; Module properties: Unfenced booster module (BOOST); Input voltage: Two optional input voltage range (select through the jumper line); 8~16V input: (for three series of lithium electricity and 12V battery), In the state of this input, do not overpressure input or you will burn out the module; 12~60V input: The factory default range (With wide input voltage range); Input current: 16A (max.) more than 10A please enhance heat dissipation; Static working current: 15mA (12V up to 20V, The higher the output voltage, the static voltage will increase); Output voltage: 12~80V continuous adjustable; Output current: 12A max., more than 10A please strengthen heat dissipation (related to the input / output differential pressure; The smaller the pressure difference, the greater the output current); Constant current range: 0.1~12A; Output power: = input voltage x 10A, such as: input 12V x10A = 120W, input 24V x 10A = 240W; Input 36V x 10A = 360W, input 48V x 10A = 480W, input 60V x 10A = 600W; If you need more powerful, can be used two modules in parallel, such as the output to 15A, can use two modules in parallel, the current of each module can be transferred to 8A; Working temperature: -40'C~+85'C (please enhance heat dissipation when the environment temperature is too high); Working frequency: 150KHz; Transfer efficiency: Up to 95%. (efficiency related to the input / output voltage, current, differential voltage); Over current protection: Yes; (Input more than 17A, reduce output voltage automatically, has the certain range of error); Short-circuit protection: Yes. (Enter 20A fuse). Double short circuit protection, to make it more safety; Input reverse connect protection: No. ( If needed, please input diode series); Installation method: 2 PCS 3mm screws; Connection mode: Output terminal without soldering; Module size: 76mm x 60mm x 56 mm (L x W x H); Application scope: DIY a regulated power supply, input 12V, output can be 12~80V adjustable; Supply power for your electronic equipment, can set output value according to your system voltage; As a automotive power supply, can supply power for your laptop, PDA or all kinds of digital products; DIY a high-power notebook mobile power supply, with large capacity 12V lithium battery series, which can let your laptop go wherever you like; Solar panel regulator; Recharge storage battery lithium battery, etc.; Driving high power LED lights
Packing List   1 x Module
Dimensions: 2.99 in x 2.36 in x 2.20 in (7.6 cm x 6.0 cm x 5.6 cm)
Weight: 7.23 oz (205 g)
http://www.dx.com/p/600w-constant-voltage-constant-current-power-car-charger-solar-regulator-dc-dc-boost-module-blue-228310#.WNvQo72OHMJ
Новый, не пригодился. 650 руб.
2)Новая ручка "газа" с ключом + индикаторы. 650руб.
« Последнее редактирование: 29 Мар 2017 в 18:57 от caprid »
Интересная вещь велосипед, попа едет, ноги нет... Теперь ноги то же едут!
АндрейS
  • Старожил
    +33/-1
    162
    241
  • Московская обл, г. Реутов, улица Южная, дом 15
  • Оффлайн Оффлайн
    • Награды
Прошу бронь до пятницы.
Пересыл возможен?
caprid
  • Начинающий
    +0/-0
    13
    2
  • Санкт-Петербург
  • Оффлайн Оффлайн
    • Награды
, без пересыла, только самовывоз.
АндрейS
  • Старожил
    +33/-1
    162
    241
  • Оффлайн Оффлайн
    • Награды
Жаль. Тогда извините.
Страницы: 1Вверх
