avatar_zap
Посмотрите что я нашёл!
Автор zap, 19 Март 2012 в 00:00
Silvaticus
[user]luckydevil[/user], я как-то не понял ваших проблем с переводом, по-моему и так все понятно.
Special shipping activity has ended, restore the original price.
Adjust the control panel link http://item.taobao.com/item.htm?spm=0.0.0.31.A174Se&id=18687783315
There are a number of electric car alliance forum posts this controller can be used as a reference test (copy to IE open): http://www.ddclm.com/bbs/viewthread.php?tid=237626&page=1&extra = # pid1840979
The main function :36-84V adjustable reversing (ZWK84300A have reverse function), E-ABS, self-learning, brake recoil power adjustable hard and soft start, undervoltage bus line current is adjustable overvoltage protection
Glue the whole interior sealed, waterproof, shockproof, and promote heat!
ZWK84160A controller Overall size is half the size 84300A controller: 13 0mm * 120mm * 60mm , easy plug-in or built-in installation
Specifications
1 The maximum phase current limit : ZWK-84300ACan be set to phase nominal 300A (the actual maximum 360A )
ZWK-84160ACan be set to phase nominal 160A (the actual maximum 180A )
2 . applicable voltage : 48V, 60V, 64V, 72V, 84V (battery pack)
3 . Output Power : 1500W, 2000W, 2500W, 3000W, 5000W
4 . undervoltage protection : According to the battery specifications set
5 . motor phase angle : 120 °
6 . Turn the voltage :1.35 - 3 .2 V
Scope: light electric vehicles, electric tricycle, electric golf buggy transport, high-power electric motorcycles, hybrid vehicles, electric forklifts, electric boat, electric ATV, energy efficient pumps, industrial energy-saving motor.
Features:
1, Powerful microprocessor
2, high-speed low-loss synchronous rectification PWM modulation
3, stringent current limit and torque control
4, the battery current limit function does not trigger the battery current limit protection, extended battery life.
5, a larger starting current, can get faster boot
6, anti-electromagnetic interference, anti-vibration and strong performance
7, fault indicator indicate various fault, user testing and maintenance
8, with electronic commutation function
9, has a battery protection function: When the battery voltage is low will be timely and current decay alarm, stop the output when the battery is too low to protect
10, limiting technology innovation phase , dual Hall current sensor detects the motor phase currents . Compared with Hong copper controller , can effectively reduce heat , improve the current detection accuracy , creating the necessary conditions for the stable operation of the controller
11, the controller temperature detection and protection capabilities , real-time detection controller internal temperature sensor operating temperature , when the temperature reaches 90 degrees after , reduce running current ; over 100 degrees , the controller turns off the output, perform temperature protection
The main function
1, Configuration 1-4V Linear Hall to the governor.
2, high and low brake choice
Built-high (+12 V) signal input brake effective and low (ground) signal brake effectively two brake modes, allowing users to choose according to need.
3 , strengthen the power brake function. Original E - ABS braking technology to make your brakes more powerful and stable. And motor braking energy generated can be recycled to recharge the battery and extend mileage.
4 ,Reverse function
When the reverse low signal input port, an output controller stops forward and began to detect the rotational speed of the motor, the motor speed is reduced when it detects very low, and turned back to zero again put together, the controller controls the motor start reversed. The default maximum speed forward reverse maximum speed of 30 %, can be set as desired.
5 , self-learning function
First self-learning lines on the plug, then open the electric door lock, then the controller will enter the self-learning state. Few opportunities for low speed electric, pay attention to see the controller LED indicator lights flash if the next six, indicating that self-learning is not successful, check the wiring, if you do not flash, then the self-learning success, then disconnect the wire from learning slowly add turn to see whether the controller and the motor runs smoothly, the direction is correct, if the motor reversal, then simply disconnect the power door locks, two arbitrary phase motor swap, then the Power to re-learn again. ( Note: Be sure to disconnect from the phase matching learning lines to the road after a successful ride )
6 ,Manual, automatic cruise function
Users can manually customize according to individual needs, auto cruise. Cruise displayed.
7, the controller temperature protection
8, custom parameter function
The controller phase current can be set by a dedicated programmer , bus current , voltage and other operating parameters .
9, super mute function
The current compensation using a unique technology to solve the noise problem brushless motor starts.
10, synchronous rectification
The use of synchronous rectification controller reduces heat caused by reverse-wheeling. Driving up and down the tube dead time generated by the MCU internal brushless drive module, stable and reliable.
11, various protection functions
Phase short circuit protection, stall protection, undervoltage protection, overcurrent protection, phase protection, anti-coaster protection, brake failure protection.
12, fault indication
With fault detection and display features self , LED lights indicate the fault code . User testing and maintenance.
Power on the green light , which means that working properly .
1 red light flashes once to indicate over-current protection
2 red lights flash two stall protection under the said
3 red lights flash three times, said undervoltage or overvoltage protection
4 red lights flash four times when said power-brake state is
5 red lights flash five under the said transfer voltage fault, turn to did not answer, or turn on power to not return to zero
6 red lights flashing from the study, said the next six unsuccessful.
7 . red lights flashing under eight said current sampling circuit failure.
8 . red lights flashing, said the lack of protection under ten
9 . red lights flash motor line indicates a short circuit protection under the Eleventh
13 custom functions
You can customize the reverse , third gear , cruise , electromagnetic brake , brake anti-charging and other functions .
14, the soft under-voltage technology
Soft undervoltage technology automatically flow down when the battery is dead , that is to protect the battery , and continue to improve the mileage .
15 professionally designed aluminum heat power
260mm * 120mm * 60mmBeautiful and can quickly heat aluminum with heat sink design shell , effectively reducing the operating temperature controller to ensure stable and reliable controller.
One year warranty, overdue maintenance fees.
Please consult:
QQ: 864974735
Mobile: 15867937697
Email: 864974735@qq.com
Payment:
1, PayPal payment
2, bank direct debit ( must promptly told me after the transfer contacted for confirmation, indicating the remittance business, so that we can ship to you in the first time ).
IvanM
[user]Indiсtа Саusа[/user], это то все понятно. Не ясно как с помощью этой штуковины с 4-символьным дисплеем все это настроить )))
Получается этот контроллер аналог инфинеона, только с расширенными функциями: самообучение, плавный старт, пониженный шум двигателя (типа как у келли)
Skrytyi_kachok
#1208
iCharger 1-6S 20A/300W power multifunctional balance charger / 206B
http://item.taobao.com/item.htm?spm=a230r.1.0.0.pDQ6Bs&id=18331553664
Как вам? всего 35 юаней. Ошибочка вышла, как меня поправили, это всего лишь плата.
Rocky Mountain Flatline 2012. Надеюсь скоро начну новый проект на этой раме.
Проект из двухподвеса "Rocky Mountain" проект закрыт, элекроника пошла по барахолке.
Мой проект не связанный с ЭТ: Custom-case из алюминия "Dark Defender" закрыт (родился мертвым).
vestor11
а описание почитать?......
за 35 Юаней получаешь только плату адаптера....
а вот сам чарджер уже за 115 баксофф
KONA STINKY
e4bike.ru
Цитата: Nathan от 19 Фев. 2014 в 13:50
Уважаемые форумчане, что скажите на счёт этого мотора:
http://www.aliexpress.com/item/5000w-electric-bike-motor-5kw-brushless-electric-bike-motor-5kw-e-bike-hub-motor/1401327505.html
Обмотка 4x20. Только на сколько он тяжелее крошки: то ли на 2 кг, то ли на 4 кг (там фигурируют две цифры 12 и 14 кг)?
И придется разжимать треугольники, так как ширина дропаутов 149мм? Ваше мнение.
Кажется именно этот мотор заказывали на сфере. Там действительно 150мм, но ось мотоциклетная 12мм.
Весь ассортимент здесь!
Skrytyi_kachok
[user]vestor11[/user], спасибо что поправили.
Nathan
А случайно нет ссылки на пост, может хоть за бугром есть более конкретная информация?
ppi1
Эта зарядка под лэйблом Turnigy Reaktor 300W 20A 6S продается на ХК- http://www.hobbyking.com/hobbyking/store/__44112__Turnigy_Reaktor_300W_20A_6S_Balance_Charger.html
При цене 65$, по бадди-коду можно получить скидку до 56$ - http://rcsearch.ru/hobbyking/i44112/
Получил. Внутри прошивка 206В, версия 3.14, свежак.
донор: Stels Navigator 310 | акк: 36V10AH Headway 38120 LiFePO4 | мк: QQ-128Front 500W| контроллер: NN 15А
Nathan
В общем китаец мне написал, что диаметр медной проволоки 4 мм. Магниты шириной 50 мм, обмотка 4x20. А каков диаметр проволоки у крошки и кваншуня?
spb-e
9II-I82-78-78
IvanM
[user]Nathan[/user], в моем 3-х витковом кваншуне намотка 26*3, жилой 0,5.
Nathan
#1217
А у кого крошки или кваншуни на 4 витка, каков диаметр жилы и расстояние между дропаутами? У QuanShun на 3000 Вт получается 154 мм.
IvanM
[user]Nathan[/user], а у 4-х виткового намотка 18*4, провод вроде как тот же
Yurij122
VasiliSk
#1220
[user]Nathan[/user], этот мотор у меня идет как 20х4 или 26х3
MadMNN
MadMNN
разнообразие холдеров как наборных так и уже сразу готовых под батарею.
http://item.taobao.com/item.htm?spm=a230r.1.14.136.uh9VAy&id=21536795141#
юйбай спросил сколько будет стоить 5s13p
ответ:
about 6.72 dollars for 4 pieces
MotoVlad
Нашел дилера ака производителя  самокатика в Румынии. Их сайт одноименный e-twow.com
Но их сайт совершенно не информативный. Как там покупать , какие гарантии и т.д. Могут и кинуть же. Как быть ?
ПыСы. За бугром ещё не покупал нечего.
