avatar_powersupermax
Bafang BBS движок под каретку
dengor
[user]vitali[/user], ну не знаю, не знаю... Я о таком не слыхал, на нашем форуме и подавно. Это глюки какие-то не страшные. O:-)
Расставить все точки нади
hbar02
Да ну, приятного мало. У нас просто, в Раше, похолоднее, чем в Австралии или Штатах, чьи жители тусят на сферах в основном. Если вжаривать по жаре  :-) , то контроллер быстро помрет. Еще там у людей выдавливало уплотнитель силиконовый. Это не знаю как. Я регулярно пшикаю в район подшипников силиконовой смазкой - она и воду отталкивает, и грязь вроде не так липнет.
Stels Navig 650 disk, BBS02, bmsbattery LiFePo4, 10Ah
vitali
ЦитироватьHello all,
Believe me or not and forgive me if this is a repost of information but I frequently speak with Vendors (Both friends and clients) so in addition I speak with many Chinese attempting to procure the best revisions of everything and to at minimum ensure we don't get a version with a known issue (IE: 750w version 1.0 had 6 FET issues and perhaps some minor issues we knew nothing about.
Then came patch 1.01:
This patch was done by dealers using Bafang Protocol 1.0 software (ControllerST written in delphi from way back, who uses Delphi even Visual Delphi anymore?) which many if not most of us have already, I've had since before Legrand Cruise but was NDA hence my project to reverse engineer the serial protocol and create the codebase opensource for all to benefit but before I could get 30% done the software was leaked but not by me so no more need for open source.
Please not the version 1.0 protocol was for this x1 BBS-01 - 6FET version
Next Came version 2.0, the 9FET unit
Surprise, new bafang protocol was 2.0 for the changes they made to take advantage of the 9FET setup - mind you overheating even at legitimate 25a and 48v was still an issue but it seems more a gearing and rider issue at this point *(Correctable with shift point indicator).
Then I believe it was Paul aka Cell_Man who figured out how to replace the ring gears, why? because the existing ones using now v2 software had a gearing issue so he offered a much needed aftermarket a solution, combined with claims under warranty (which only US Vendors with Reputable Chinese vendors were able to obtain).
So then emerges the v3 unit which was fantastic, no real controller issues (used within spec and geared properly, the latter they have yet to offer customer materials which focus on this but in truth these aren't supposed to be end user kits but installed by trained professionals or at least very experienced non professionals but whom know what they are doing and then some.
Guess what the issue with v3 became? Bearings! Yep somehow they figured out their bearings were failing (not an issue with v1,2,3) but introduced when gearing was fixed.
Software version for those internal controllers? Simple, can you guess - yep 3.0
Finally I became aware from a small vendor overseas (not alibaba or BMS battery related in any way) who at first handnt believed me, or wanted to) so he had just received an order of 50 units, 35 of which were states bound the rest all over. He broke the first one out (we were skyping) and loaded up the new Controller ST and guess what - v4 drives.
Since then ( a few weeks ago ) he's been pushing it as hard as the stock controller with some removed throttle delay / ramp setting for nearly 200 miles with no temperature or other issues at 15S or 55.5v.
No grinding, play, overheating or well.... no issues at all.
Moral of the story, for the least amount of headaches... ensure your vendor has v4 drives, which we currently do not as they are about to set sail but if you can't find one in the next 3-6 weeks, contact me via PM I will be glad to reserve one for you.
Hope that helps clear some of these cheaper kits up for people, in the end they may be fine for you but why risk it.
зацитатил со сферы.
vitali
вкратце сначала был шестифетовый контроллер который не тянул 48В 25А и дох, потом следующая версия диллеры прошили меньшие токи чтоб не дох, потом уже 9 фет версия но тож мог перегреваться если жарить не в себя, ну и вылезла проблема с уплотнителем, решили проблему с уплотнителем началась беда с подшипниками, пошаманили пошаманили и тадам версия 2015 на которую пока жалоб особых нет.
diod555
#1696
[user]dengor[/user],  и проблема с подшибниками осталась :bn:вот я и в раздумье что брать 500/48 или 500/36последней версии,,умоей 250/36  всё отлично,но слабовата  :-(
Bafang 36v 250w     HAIBIKE SDURO AllMtn SL YAMAHA36v 250w     Xiaomi Mijia QiCYCLE    Icarbot Currus RS11   Dualtron Thunder  Моноколесо Gotway MSuper X Inmotion V12
enje
Вот и diod555 в раздумье - что брать? Так вопрос: брать или не брать 48вольт 500ватт? Или ждать у моря погоды и не кататься на эл. веле. Вот в чем вопрос???
Удачи Вам, соратники!
diod555
я катаюсь на 250/36 и все нормально,но хочу мощнее ... а потратить деньги и приобрести проблемы не сильно охота
dengor
[user]diod555[/user], да где вы проблемы-то увидели? Вот в этой теме много проблем?
diod555
[user]dengor[/user], на сфере ,в затяжной подьем  у меня  250ватт нагревается.... а 750ватт? будет кипеть?
killer258
#1701
Поставьте,как у меня сделано,на мотор ведущую звезду в 34 зуба ,вместо штатной,а в кассете на заднем колесе перебрасываете цепь на звезду 36 зубов,и ему будет легко в затяжные подьёмы,ток будет в большинстве горок будет подыматься до 5...10 ампер,не больше,18 только в совсем уж крутых,каких единицы,или по совсем уж откровенному песку.(по горизонтальному асфальту ток у меня при данном передаточном числе вообще не превышает 2-2.5 ампера, но скорость в этом случае  всего лишь 14 км\ч в режиме максимальных оборотов мотора,хотя при езде в жилой зоне эта передача очень удобна ) Штатную ведущую можно не убирать,они у меня обе рядышком стоят,хотя я так штатной ведущей не пользуюсь.
dengor
[user]diod555[/user], на нормальной передаче ему только легче будет. Таки и где проблемы? В теории?
killer258, у вас есть проблемы с мотором?
ra6fnq
А жара - это сколько в градусах? У нас, на Северном Кавказе 35 - 40++ норма. Сегодня термометр на руле показывал 28. На каком пробеге косяки лезут? У Ольгиного BBS-02 20А пробег 4,5 тыс км, в основном не по паркету...
"Глюки" - это отмазка пользователя, угробившего технику  :neg:
Евгений
killer258
#1704
Никаких. Едет практически по любому месту,где я хочу проехать .Сегодня даже по вскопанному полю пробовал, едет  /:-)  . Мотором очень доволен.
А вообще собираюсь на базе ещё одного такого же мотора  сделать ещё один аппарат,для триала. Там даже этого передаточного числа будет всё же недостаточно, надо будет на заднее колесо ставить звезду зубов примерно под восемьдесят,вот её придётся изготавливать,готовых скоее всего не существует.
dengor
А говорят есть какие-то эпические глюки, о которых у нас не слыхали. %-)
diod555
[user]killer258[/user],  спасибо  буду на новом моторе ставить звезду меньше... сейчас 48,,а с зади 9 передачь  ,29колеса
killer258
если не читали  эту тему целиком, просмотрите, у меня там в  одном из постовбыли приведены фото этой доработки.
diod555
нет   :-\ бегло просмотрел.... поишем
enje
#1709
          Тогда, надо брать 48в/500вт, а поэкспериментировав с шестеренками, добиться оптимальной скорости и мощности (силы тока) на моторе. На али моторы мощностью 750вт - не много ли? Хотелось бы 500. Или запас не помешает?
          На али предложений много, цена, примерно =25000р с доставкой, на http://www.elifebike.com/ = 385$ с доставкой +160$ (EMS). Вопрос: дисплей лучше С965 = 15$ (не огрызок с965А) или 963 = 30$, или 961? Спасибо:  killer258, dengor, ra6fnq.
        Проверенного продавца нет?
