avatar_aka2000
ZXY6020 в качестве ЗУ?
Автор aka2000, 05 Апр. 2014 в 21:33
aka2000
Как вам такая зверюшка? Будут ли противопоказания? Очень уж мне нравится.
http://www.aliexpress.com/item/ZXY6020-CNC-constant-voltage-constant-current-power-supply-DC-13-62V-to-0-60V-20A-1200W/1599256711.html
ZXY6020 CNC constant voltage constant current power supply DC 13-62V to 0- 60V 20A 1200W Programmable voltage Regulated
Features:
    Low ripple and low noise
    CC,CV and output status ON indicator
    LCD display the output voltage, output current, output power, output power (AH),working time
    With output shutdown function keys, turn on or off the output
    M0 ~ M9 total of 10 groups parameter settings
    Onboard buzzer or alarm function operating tips
    TTL serial communication interface,provides serial communication protocol, support secondary development,can be connected to computer software control
Operating Parameters:
    Module Properties:Programmable Constant voltage constant current (BUCK) Module
    Input voltage range: DC 13V ~ 62V
    Output voltage adjustment range: DC 0 ~ 60V
    Output current adjustment range: 0 ~ 20A (If 20A full load and works long hours, please install a fan to enhance heat dissipation)
    Output power: 0 ~ 1200W
    Output voltage setting resolution: 10mV
    Output current setting resolution: 10mA
    Minimum voltage difference: 2V
    Power effect: CV less than 0.5% +10 mV; CC is less than 1% +5 mA
    Load effect: CV less than 0.5% +10 mV; CC is less than 1% +5 mA
    Output ripple: <50mVpp (input 54V, output 12V, current 8A)
    100Hz wave transmission ratio: <1/10 000
    Typical efficiency: 88% (input 54V, output 36V, current 8A)
    Voltage and current display accuracy: 10mV, 10mA
    Voltage display error: ± 1% +50 mV
    Current display error: ± 2% +20 mA
    Response time: <50ms
    Display: LCD1602
    Storage operations: M0 ~ M9 total of 10 groups parameter storage
    Type of protection: OTP, OVP, OCP, OPP, OAH, OFT
    Operating Environment Temperature: 0 ~ 40 °c
    Storage temperature: -20 ~ 70 °c
    Environment: Indoor use design, maximum humidity 80%
    Power Module size: 130mm (L) * 85mm (W) * 75mm (H)
    Control Module size: 130mm (L) * 85mm (W) * 43mm (H)
    Requires a detailed user manual, please contact us.
Package Include:
    1x Programmable DC-DC Power Supply Module
Продаю новую пространственную раму для мощного электровелосипеда https://electrotransport.ru/index.php?action=fads;id=1839
Mandarin
Допустим, но ее ведь тоже нужно чем-то питать.
Ригид GT Avalanche 2.0 MAC 8T front + infineon EB309 cellman | 14S LiPo "Монстры" | Meanwell NES-350-48 (x1, x2) в качестве зарядника. Делаю лигерад :D (Прогресс: 75%, пробег: 3691 км)
aka2000
Трансформатор подобрать.
linnard
[user]aka2000[/user], Идея неплохая, кстати пробовали? Какой результат?
destroyer85
я такую купил месяца два назад.с хорошим бп превосходная заряжалка.
использую с бп 36в 7а (временно)
currus m10pro-kugoo m4s-specialized big hit expert bbs2 currus m10+ Rhino2023
Silvaticus
destroyer85
с вентилятором и корпусом около 1.5кг вышло.точно не ызвешивал.
вентилятор советую ставить,там его даже с платы подпитать можно,есть выход на него.
vitali
есть как бы альтэрнатива попроще подешевше наворотов по меньше но есть CC/CV и повышайка http://www.aliexpress.com/item/8V-to-80V-10A-400W-DC-step-up-converter-Adjustable-boost-converter-with-digital-dispaly-Automatic/1547866469.html
destroyer85
да их много,я из 5 ти моделей выбирал.решил с запасом взять.
был совсем дешевый,года три проработал,сгорел.
брал на дх,помоему рублей 700 стоил.
dimad63
А до 100в  не попадались ?
destroyer85
мне нет,но я и не искал.в теории могут быть.
Andy74
Я лично купил такую же как предлагалось ниже (только на ebay, там она 20 евро).
За скоростями заряда не гонюсь, по приезду питаю от нотбучного БП. На выходе выставляю
1.2А 43.5В для БП 40w и 1.5А для 60w-атника.
