Контроллер VESC, FLIPSKY
Автор Said, 14 Дек. 2018 в 21:21
РД00
Вторая версия кастомного RT Data.
    Copyright 2017 - 2019 Benjamin Vedder    benjamin@vedder.se
    This file is part of VESC Tool.
    VESC Tool is free software: you can redistribute it and/or modify
    it under the terms of the GNU General Public License as published by
    the Free Software Foundation, either version 3 of the License, or
    (at your option) any later version.
    VESC Tool is distributed in the hope that it will be useful,
    but WITHOUT ANY WARRANTY; without even the implied warranty of
    MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
    GNU General Public License for more details.
    You should have received a copy of the GNU General Public License
    along with this program.  If not, see <http://www.gnu.org/licenses/>.
import QtQuick 2.7
import QtQuick.Controls 2.2
import QtQuick.Layouts 1.3
import QtQuick.Controls.Material 2.2
import Vedder.vesc.vescinterface 1.0
import Vedder.vesc.utility 1.0
import Vedder.vesc.commands 1.0
import Vedder.vesc.configparams 1.0
Item {
    anchors.fill: parent
    property Commands mCommands: VescIf.commands()
    property ConfigParams mMcConf: VescIf.mcConfig()
    property bool isHorizontal: rtData.width > rtData.height
    property int gaugeSize: Math.min(width / 2 - 10,
                                    (height - valMetrics.height * 10) /
                                    (isHorizontal ? 1 : 3) - (isHorizontal ? 30 : 20))
    Component.onCompleted: {
// --------------- EDIT HERE --------------------
// ------- Gauge max/min values -----------------
        // Motor current max
        currentGauge.maximumValue = mMcConf.getParamDouble("l_current_max")
//        currentGauge.maximumValue = 150 // Manual set
        // Battery current max
        currentInGauge.maximumValue = mMcConf.getParamDouble("l_in_current_max")
//        currentInGauge.maximumValue = 100 // Manual set
        // Power max
        powerGauge.maximumValue = 6000
        // Voltage min/max
        voltageInGauge.minimumValue = 48
        voltageInGauge.maximumValue = 56
        // RPM max
        rpmGauge.maximumValue = 6000
        mCommands.emitEmptyValues()
    ColumnLayout {
        anchors.topMargin: 5
        GridLayout {
            Layout.fillWidth: true
            Layout.fillHeight: true
            columns: isHorizontal ? 4 : 2
            Layout.leftMargin: 5
            Layout.rightMargin: 5
            Layout.topMargin: 5
            Layout.bottomMargin: 5
            CustomGauge {
                id: currentGauge    // MOTOR CURRENT
                maximumValue: 100  // Max phase current
                minimumValue: 0
                labelStep: maximumValue > 60 ? 20 : 10
                value: 0
                unitText: "A"
                typeText: "Motor\nCurrent"
                Layout.preferredWidth: gaugeSize
                Layout.preferredHeight: gaugeSize
            CustomGauge {
                id: currentInGauge    // BATTERY CURRENT
                maximumValue: 60    //Max battery current
                minimumValue: 0
                value: 0
                unitText: "A"
                typeText: "Battery\nCurrent"
            CustomGauge {
                id: voltageInGauge    // VOLTAGE
                maximumValue: 42    // 10S fully charged
                minimumValue: 32    // 10S discharged.
                labelStep: 1
                value: 0
                unitText: "V"
                typeText: "Voltage"
                centerTextVisible: false
                Text {
                        color: {color = Utility.getAppHexColor("lightText")}
                        text: "VOLTAGE"
                        font.pixelSize: gaugeSize/15.0
                        anchors.verticalCenterOffset: -gaugeSize/6.5
                        verticalAlignment: Text.AlignVCenter
                        anchors.centerIn: parent
                        anchors.margins: 10
                        font.family:  "Roboto"
                Text {
                        text: "36.2"
                        font.pixelSize: gaugeSize/6
                        anchors.verticalCenterOffset: 0
                        anchors.margins: 10
                Text {
                        text: "98%"
                        font.pixelSize: gaugeSize/8
                        anchors.verticalCenterOffset: gaugeSize/6
                        anchors.margins: 10
                    Text {
                        text: "%"
                        font.pixelSize: gaugeSize/8.0
                        anchors.verticalCenterOffset: gaugeSize/1.4
                        anchors.margins: 10
            CustomGauge {
                id: powerGauge    // POWER
                maximumValue: 2000
                minimumValue: 0
//                tickmarkScale: 0.001
//                tickmarkSuffix: "k"
                labelStep: maximumValue > 2000 ? 500 : 200
                value: 0
                unitText: "W"
                typeText: "Power"
            CustomGauge {
                maximumValue: 4000    // 4000 RPM
                minimumValue: 0
                labelStep: 500
                value: -10
                unitText: ""
                typeText: "RPM"
            CustomGauge {
                maximumValue: 100
                minimumValue: 0
                labelStep: 10
                value: 0
                unitText: "%"
                typeText: "Duty"
        Rectangle {
            color: Utility.getAppHexColor("darkBackground")
            Rectangle {
                anchors.bottom: valText.top
                width: parent.width
                height: 2
                color: Utility.getAppHexColor("lightAccent")
            Layout.preferredHeight: valMetrics.height * 5 + 20
            Layout.alignment: Qt.AlignBottom
            Text {
                text: VescIf.getConnectedPortName()
                font.family: "DejaVu Sans Mono"
                anchors.leftMargin: 10
            TextMetrics {
                font: valText.font
                text: valText.text
    Timer {
        interval: 100
        running: true
        repeat: true
        onTriggered: {
            if (VescIf.isPortConnected()) {
                        mCommands.getValuesSetup() // For battery % only
    Connections {
        target: mCommands
        function onValuesSetupReceived(values, mask) {
            currentGauge.value = values.current_motor  // Motor current
            currentInGauge.value = values.current_in    // Battery current
            voltageInGauge.value = values.v_in          // Voltage
            voltageValue.text = parseFloat(values.v_in).toFixed(1)
            voltagePercent.text = parseFloat(values.battery_level * 100.0).toFixed(0) + "%"
            dutyGauge.value = values.duty_now * 100.0  // Duty
            // 10 for inrunners, 14 for outrunners
            var motor_poles = mMcConf.getParamInt("si_motor_poles") / 2
            rpmGauge.value = values.rpm / motor_poles  // RPM
            powerGauge.value = (values.current_in * values.v_in)  // Power
            valText.text =
//                    "Temp MOS  : " + parseFloat(values.temp_mos).toFixed(2) + " \u00B0C\n" +
                    "Temp MOS  : " + parseFloat(values.temp_mos).toFixed(2) + " \u00B0C" +
                    "        Motor kV : " + parseFloat(rpmGauge.value / (values.v_in * values.duty_now)).toFixed(0) + " \n" +
                    "Temp Motor : " + parseFloat(values.temp_motor).toFixed(2) + " \u00B0C\n" +
                    "Ah Draw    : " + parseFloat(values.amp_hours * 1000.0).toFixed(1) + " mAh\n" +
                    "Wh Draw    : " + parseFloat(values.watt_hours).toFixed(2) + " Wh\n" +
                    "Fault      : " + values.fault_str
//                    "Debug      : " + parseFloat(values.battery_level).toFixed(2)
