Нашел на просторах зарубежного интернета.
FUTECHER GUN PRO ELECTRIC SCOOTER$1,100.00
Introducing the New Futecher Gun Pro Electric Scooter from MiniMotors. We packed unprecedented performance and range into this scooter at the lowest possible price. This little beast stuffs a huge 52 volt, 20.8Ah pack with a BLDC rear hub motor running at 1,760 watts max power into a 46 lb scooter. Stopping power comes from dual front and rear drum brakes and an electric brake. You get all the top features of the higher end MiniMotors products such as regenerative braking, ABS, stem lighting, and Ey3 throttle functionality.
ссылкаSPECSMotor: MAX 1,760 watt BLDC hub motor
Battery: 52 volt - 20.8 Ah - 1082 Wh - Sinc Power Cells
Charge time: 11 hours with standard charger
Max mileage: 45 miles (mileage may vary depending on rider weight and road conditions)
Max Speed: 31 mph
Climbing Grade: 27% depending on rider weight and state of charge
Braking System: Regenerative Electric Front and Rear Drum Brake with ABS
Tires: 8 inch tubed pneumatic front tire and solid rubber rear tire.
Max Load: 265 lbs
Scooter Weight: 46 lbs
Product Material: Aluminum Alloy Frame
В Россию, я так понял, их не завозят.
Тюнинг симпатичный, цена нет.
