ссылка
Battery type
3.65V Prismatic pouch lithium ion battery pack
Nominal Voltage(V)
3.65V
Nominal Capacity
102Ah
Cell inside
3.65V 3*34AH NMC cells
Configuration
3P1S
1Max charge current
1C
Max discharge current
3C
Standard Charge current
0.2C-0.5C
Charge Voltage
4.2V
Discharge cut-off voltage
2.75V
Weight Energy density
220WH/KG
Internal resistance
≤ 1.4mΩ
Dimensions
30*115*375mm
Cycle Life
1500times(80% of initial capacity at 0.2C rate, IEC Standard)
Operating Temperature
Charging: 0~55Centigrade
Discharge Temperature(℃):
-20~55Centigrade
Storage Temperature
-20~45Centigrade
Connector
Threaded terminals
