Li-Force батарея 48V 10AH LiMn2O4 весом менее 4 кг
avatar_MadMNN
Автор MadMNN, 05 Фев. 2012 в 23:57
MadMNN
бродил о ебею
набрел на аккум
http://www.ebay.com/itm/48V-10AH-LiMn2O4-Battery-Flat-Aluminium-Case-/110716954789?pt=US_Batteries&hash=item19c73ea8a5#ht_1950wt_1112
US $428.00
параметры понравились очень
Battery Model   48V 10AH
Nominal Capacity (AH)   10.50
Nominal Voltage (V)   48
Source Resistance (m)   105
Cell Combination   3-parallels
13-series
Cell Quantity (parallel*series)   39
Discharge Cutoff Voltage (V)   120
Charge Cutoff Voltage (V)   54.6
Rated Discharge Current (A)   16
Instantaneous Maximum Discharge Current (A)   120
Maximum Continuous Discharge Current (A)   30
Maximum Continuous Charge Current (A)   10
Charge Mode   CC-CV
Standard Charge Current (A)   12
Charge Time under Standard Charge Current   2 hours
Fast Charge Current (A)   19.5
Charge Time under Fast Charge Current   1.5 hours
Charge Temperature Range   0-50
Discharge Temperature Range   -20-50
Battery Net Weight (include BMS) (gram)   ≤4000
кто что думает? можно ли такую брать?
ну или такую
http://www.ebay.com/itm/48V-10AH-LiMn2O4-Battery-Plastic-Case-and-Charger-/230740327273?pt=LH_DefaultDomain_0&hash=item35b931fb69#ht_1939wt_1346
