Xiaomi QiCYCLE - EF1 Smart Bicycle (в продаже)
Автор Nitro785, 20 Сен. 2016 в 08:10
Nitro785
 Собственно сабж
http://www.gearbest.com/bikes/pp_434406.html
- This bike is powered by 18650 lithium-ion battery pack with the total capacity of 208.8Wh, which means the cycling distance can be up to 45km at the condition of 100pct electric power.
- The smart folding bike comes with a trip computer, so you can directly view the mileage, speed, power and other data without a mobile phone, and the built-in space can store 30 days of riding data, moreover, these data can be exported at any time.
- The bicycle is equipped with three-mode derailleur, which makes it effortless to ride even without power.
- Equipped with TMM torque sensor and professional electric boosting system, the smart bike can automatically sense your tread power, and output the appropriate electrical power to assist cycling.
- Longitudinal folding design, easy to operate and no harm to the bike frame.
- Aluminum alloy frame, lightweight and exquisite.
Specification:
- Unfolded size: 1247mm x 556mm x 928mm
- Folded size: 1000mm x 450mm x 650mm
- Frame: aluminum alloy
- Front fork: aluminum alloy
- Crankset: aluminum, 52T x 170mm
- Seat tube: aluminum, 33.9 x 580mm
- Hub: three-mode derailleur
- Weight: 14.5kg
- Wheel size: 16 inches
- Wheel rim: 1250mm
Motor:
- Rated power: 250W
- Rated torque: 7.3N.m
- Maximum speed: 20km/h
Battery:
- Type: 18650 lithium-ion battery
- Working distance: about 45km
- Capacity: 5800mAh / 208.8Wh
- Charging time: about 3 hours
- Limited charging voltage: 42V
Brake:
- Braking methods: caliper brake for front wheel, IM31 roller brake for rear wheel
- Braking distance: not more than 4m in dry state, not more than 15m ( speed of 20km/h ) in wet state
Control Dial:
- Screen: 1.8 inch, 160 x 128 TFT
- Wireless connection: Bluetooth 4.0 BLE, effective range of 15 - 30 meters
2 самоката, 2 велика, гироскутер.
vasya976
Безвозмездно, то есть даром.
Nitro785
ВОт у него уже человечское навесное.
По аналогии с nine bot mini и pro, ждем евро версию с более мощным мотором.
И можно брать.
Качество у ксяоми норм
ra6fnq
Про навесное в описании ни слова не сказано, но 36v 6 Ah для меня маловато. Подвески нет, мелкий эдьтреко сразу становится предпочтительней.
Качество нормальное, для того, чтобы продать (избавиться) или купить (хомут на шею, порося...)
Велик риск, что при доставке наша поШта что нибудь сломает/погнёт...
Евгений
Nitro785
Много лет покупаю и велики и запчасти с чайнреакшн, с доставкой ПР  - все ок.
Навесное SHIMANO Nexus
Первый напоминает вел, собранный из остатков металлолома. Второй от него не далеко ушел, и зачем при наличии такого свободного места в раме вешать акум сзади - для меня большая загадка. Тем более характеристики скромные даже для "бабушковоза". В общем для кого сей вел делался и кто его купит для меня тоже большая загадка.
В ближайший магазин, банк, аптеку съездить - пойдет.
Такие велики и не должны быть дальнобойными или быстрыми.
С такими колесами, 23км/ч - это оптимальная скорость. Главное - размеры и вес. В наших городах уже становится тесно для велов с 26" колесами. Слишком много места занимают на дороге.  :-D
точнее, на людном тротуаре :ah:
volk0001
[user]илс[/user], лично на найнере себя вполне комфортно чувствую)
[user]volk0001[/user], кто бы сомневался, что лично вы чувствуете себя  комфортно верхом  на найнере.  B-)
Я надеялся, что  у вас хватит ума смелости сделать это заявление от имени многочисленных пешиков, на тротуаре.  :ah:
#9
"В ближайший магазин, банк, аптеку съездить" - лучше подойдет электросамокат. Вот например мой самокат по всем характеристикам превосходит этот электровел. И нет проблемы с оставлением на улице "дорогой игрушки" - я самокат везде беру с собой, замечаний нигде не было (кроме разве что небольшого "ворчания")...
И даже если взять обычный китайский складной электровел за ту же цену например, и то он смотрится на порядок лучше не говоря о характеристиках...
[user]Slider[/user], да, это верно.
Но на самокате нельзя крутить педали.  :-)
А педали - это бОльший пробег при малом весе.
Кроме того, по нашим дорогам, самокатные колеса плохо ездят, ...не быстро.  :pardon:
ra6fnq
- с этой задачей у меня безмоторный Стелс-450 отлично справляется - на 2-3 км съездить, мотор не нужен.
Евгений
racer
Я не стал бы даже его обсуждать,маленький велосипед для маленьких китайцев.
Nitro785
Ну... так то оно так)
Но качество и технологии Xiaomi вселяют надежду).
146й
чем он привлекателем - так весом и оригинальным дизайном. а вот скорость конечно маловата.
хорошо, если дизайн сочетается с прочностью и жесткостью рамы.
если случаем не скопировали с какого -нибудь дизайнерского проекта за 9.999USD?
У каждого конечно свои вкусы, но набор труб, сбежавших со склада металлолома, как по мне, дизайном не являются ;)
Lunkin2910
Получил наконец я свой qicycle.Велосипед действительно удобный, не смотря на малый диаметр колёс и низкую раму. Сидишь на нём в естественной позе, спина не устаёт.  Сидеть удобно и комфортно, велосипед ощущается очень уверенно и естественно. Для хранения на балконе или перевозки в багажнике его складная конструкция подходит идеально. Внешний вид у велосипеда отличный, хоть и странноватый. Но какого-то отторжения не вызывает, даже наоборот. До этого на электровелосипедах не катался и должен сказать, что он поразителен! Маленький моторчик, стоящий на переднем колесе, в максимальном режиме просто вырывает велосипед вместе с вами вперед.Сделал небольшой обзор на распаковку
Lunkin2910
