avatar_Alex_Soroka
Китайцы снова радуют - трехколесник...
Автор Alex_Soroka, 19 Янв. 2009 в 15:29
http://www.erider.cn/product.asp
http://www.erider.cn/proinfo.asp?id=23
The new 3 wheelers called HaiQ scooter,which have great improvement compare with original one.
1) More tighten Handlebar. We use the same solution as Bicycle handlebar and quick release button will shorten the length of handlebar easily which could be  put inside the rear trunk of SUV car.
2) The chassis/fork connector is tighten by 4 srew instead of 2 *,It will never move or shake at any condition .
3) Battery have 2 option, Economical 36V10AH or Long range 36V20AH *. Battery are fixed by metal strap which never loose even turn over the whole vehicle.
4) Key switch are set on the handle bar for easily operation and new LED electric indicator is very clear and convience.
5) New 350W planetgear motor have bigger torque and speed up to 28km/h. 2mm thickness drum brake ensure of immediately stop at any speed.
6) Hand brake ensure of the stable stop on slope.
7) Outside controller have simple wiring and easily inspection.
8) LED headlight is more economical and brighten.
9) Outside horn sounds more clearly and alarmly.
10) Seperated package have more protection on scooter with the same container quantity.
The following are new specification:
MAX SPEED           : 28KM/H
RANGE                 :  25km at 36V10AH battery and 50km at 36V20AH battery
                           Range will vary significantly depending on hill grade, speed, and rider weight.
MOTOR                : 350 watt geared motor
CHARGING TIME    : 4-6 hours for pennies
BATTERY             : 36V 10Ah  or 36V20AH option
BATTERY TYPE     : Sealed lead acid
TIRES                 :  Pneumatic
COLOR                : Orange / Black
WEIGHT              : 69 lbs.
COMES WITH       : Basket, Headlight & Horn, seat
CONTAINER QNTY : 300pcs/40'HQ
PRICE                 : Usd198/pc based on 20' quantity and Usd190/pc based on 40' quantity.
                           Seat add Usd10/pc,basket add Usd10/pc, 20AH better add Usd30/pc
This flexible scooter could be use in big workshop,super mall,airport and all kind of OFF road area.
valery
А мне вот это понравилось.
3000W electric scooter with SP-36
http://www.youtube.com/watch?v=z_HJhNYs34g
А вот еще интересный вариант. Я так понял у него педали в помощь.
http://www.youtube.com/watch?v=kLdnW5Vi5wk
Overrider
Интересная конструкция, надо будет запомнить :)
